I bought an old Marlin boat and it needs some fiberglass repair
This boat I bought has engine mount stringers that are made out of wood with fiberglass all around them.
The wood is rotten inside the fiberglass and I want to repair the stringers.
I am looking for information about how to go about doing that.
Any guidance or assistance would be greatly appreciated
I live in Western Oregon, USA if that makes any difference.
So if you are running a boat repair place outside of the pacific northwest I will not be able to take the boat to you.
Contact me at [email protected]
yes, definetly post up pics in the FG section. Lots of guys on here have made it through this exact project with some coaching from the members here.
Its not a particularly difficult process but does require some good tool skills and can be labor intensive. A lot of cutting and grinding, etc. Also requires a lot of planning ahead but thats where the coaching comes in, i refer to it as "staying out of trouble"
08 OPA High Points Champion
Yes, there are plenty of videos of people repairing fiberglass. My question is why would anyone use wood to fill fiberglass structures, especially around the bilge area, and when I repair it what kind of material should I use to put in place of the wood? I would not want it to rot out again.
oh and the composite panel products you should be looking at are Space Age Synthetic - Thermo-lite Tough in the 24 to 26 lbs range or Coosa - Nautical 24
http://www.coosacomposites.com/
index.html
index.html
Thank you Glass Dave.
The stringers are strictly for motor mount because all of the thrust in this design goes on the transom. The shaft that goes into the drive is a slip fit.
I will search for the Thermo-lite Tough in the 24-26 pound range.
https://www.offshoreonly.com/forums/...che-scout.html
