9 pin efi wiring >
9 pin efi wiring
9 pin efi wiring
Old 12-09-2018 | 03:36 PM
F-2 Speedy's Avatar
Default 9 pin efi wiring
someone have a 9 pin efi engine harness pic, needing cannon plug pin out
thanks
F-2 Speedy is online now
Old 12-09-2018 | 04:05 PM
Tinkerer's Avatar
Wouldn't it be the same as a carb engine since the EFI is on the engine and all of the EFI wiring will be on the engine. I could be wrong though
Tinkerer is offline
Old 12-09-2018 | 04:12 PM
Yes, its the same as carb, the EFI harness attaches to the engine harness on the motor.
AllDodge is offline
Old 12-09-2018 | 04:21 PM
The arrow points where the EFI harness connects to the engine harness. Depending on SN the connector(s) can change
AllDodge is offline
Old 12-09-2018 | 04:30 PM
F-2 Speedy's Avatar
I figured they were, Im hooking up a remote ignition switch and plugging straight into the cannon plug ( engine run stand ) I can here a relay clicking when cycling the key on / off and if I got to start on the key switch the starter will engage, put the efi fuel pump wont cycle when the key is turned to on. fuses are all good and Ive changed out the fuel pump relay, still no go
Old 12-09-2018 | 04:37 PM
What motor and year?
AllDodge is offline
Old 12-09-2018 | 04:53 PM
F-2 Speedy's Avatar
its a 525 efi whipple engine
Old 12-09-2018 | 05:12 PM
Need someone with a 525 wiring diagram (I don't have one) but the FP relay is turned ON by the PCM applying a ground to one side of the relay coil. See if you have 12V on one side of the coil with the key ON but not cranking. The click your hearing might be the MPR which turns things ON but the PCM is not energizing the relay.
Now if the FP does turn ON but does not turn back ON when cranking, suggest seeing if your getting a tach signal showing at least 300 rpm when cranking
AllDodge is offline
Old 12-09-2018 | 05:35 PM
F-2 Speedy's Avatar
its a mefi 4b not a 555 controller, so thought maybe the fp driver shot craps but changed the 4b with another and does the same thing
Old 12-09-2018 | 05:49 PM
Should work the same as PCM (ground to turn on)
Measure voltage on pins 85 and 86. With key ON the pump should turn ON which one of the 2 will go from 12V to 0V, the other will stay at 12V. If nothing changes and they both stay at 12V, then the ECM is not applying a ground
AllDodge is offline
