502 cam swap >
502 cam swap
502 cam swap
Old 12-29-2018 | 07:10 PM
tripps's Avatar
Default 502 cam swap
Got a 30 single boat s bravo and cm I ex has stock flat tappet hy d cam what can is best for more power and idle motor has dart intake would the Mercruiser manifold be better over that !!! For midrange??? How about a 550 lift roller marine cam boat weighs 5500 and has a pad is as the 525 and 500 go motors don't have big lift cams thanks
tripps is offline
Old 12-30-2018 | 01:42 AM
Translate to English please
Griff is offline
Old 12-30-2018 | 07:17 PM
tripps's Avatar
My i pad does that!!!! Just looking for cam to wake up 502 in a single application 500 lb boat s pad cm i ex,
tripps is offline
Old 12-30-2018 | 09:34 PM
hp500 efi cam
sutphen 30 is offline
Old 12-31-2018 | 06:22 PM
Crane 168731 or 168741
Use the 731 if you want to keep below 5200rpms and 741 if you want to spin it faster.
Griff is offline
Old 01-01-2019 | 09:15 PM
tripps's Avatar
Default Cam
Ok 741 big ports need rpm thanks
tripps is offline
Old 01-02-2019 | 01:16 AM
Talking
Tripps, if you give some more complete details of the boat's setup as it is now and what you are trying to accomplish going forward these guys will get you moving very close to what you hoping to accomplish. I know you have a lot of OB experience but this BBC stuff isn't rocket science, you just need to use the right components to save yourself a lot of headaches and disappointments. Good luck and we like nothing better than to spend someone else's money.
sonicss42 is offline
