Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Screwing into the transom and stringers >
Old 01-04-2019 | 03:49 PM
Default Screwing into the transom and stringers
When rigging a boat and screwing cushion clamps , brackets etc. into wooden stringers and transom is there is there a way to seal the screw to prevent water intrusion into the wood? I know for bigger holes or through bolts there are methods to use with resin or fillers, but what about when you screw a bunch of cushion clamps to hold wires or hoses ? My boat is not a new build or full blown restoration but I was wondering the correct way to do it . I imagine some of you guys who put in new transom and all new stringers must seal the screws ? Maybe just a dab of marine sealant in the hole ?
tooslow is offline
Old 01-04-2019 | 04:00 PM
phughes69's Avatar
I use 3m 4200
phughes69 is online now
Old 01-04-2019 | 04:03 PM
Originally Posted by phughes69
I use 3m 4200
Thanks , I’m trying to learn as I put this boat back together .
tooslow is offline
Old 01-04-2019 | 09:59 PM
The way i did mine was by accident, but it worked out, it was faster to use bigger clamps and route everything first.
Once everything was done being routed/rerouted i went back, tugged/snugged up all the wires hoses cables etc and changed
out the cushion clamps for smaller ones and added 5200 to each screw/screw hole one at a time.
It was my first complete rebuild as well.
outonsafari is offline
Old 01-04-2019 | 10:51 PM
Thank you , that is a great tech tip . That will save me some time not loosening / tightening my clamps multiple times .
tooslow is offline
Old 01-05-2019 | 08:36 AM
I did similar to above every screw goes in then comes back out and gets sealed in the hole and on the screw.
Something no manufacture is going to do.
Wildman_grafix is online now
Old 01-05-2019 | 10:55 AM
madbouyz's Avatar
I use (and strongly recommend ) a siliconized or 'regular' polysulfide sealant . Boatlife makes a comprehensive range . And yes, I have decades of experience with the '00' materials , 4200 and 5200 , that's why I recommend their use very , very occasionally and only for very specific applications. They are without a doubt the most over and incorrectly prescribed sealants ever made , bar none .
Use those things and you're never going to get the damn screws out again later .
madbouyz is offline
Old 01-05-2019 | 01:34 PM
glassdave's Avatar
Neno the mind boggler
This is the key . . . . doesn't take a lot either, just a little dot.
08 OPA High Points Champion
glassdave is offline
Old 01-05-2019 | 04:55 PM
This makes sense , I guess the 4200/5200 is an adhesive and a sealant maybe it’s overkill?
tooslow is offline
Old 01-05-2019 | 07:20 PM
Craney's Avatar
When I redid mine I used white silicone on every screw I put in.
Craney is offline
