Water pump hose??? >
Water pump hose???
Water pump hose???
Old 01-05-2019 | 04:29 PM
Default Water pump hose???
What do i do with the hose that comes out of the top of the water pump? On my old engine it went into the front of the manifold.new motors are gm tall deck 572s dart intake, closed cooling.
thanks Chris.
chris302 is offline
Old 01-06-2019 | 09:29 AM
eliminate it............won't hurt a thing
benjen is offline
Old 01-06-2019 | 11:26 AM
Mbam's Avatar
Offshoreonly Advertiser
Actually with the setup you have it is needed. Without it there is no circulation in the block at all until the thermostat opens. A better option is a t stat housing that bypasses the heat exchanger until the t stat opens. That does the best job eliminating steam pockets.
Mbam is offline
Old 01-06-2019 | 11:48 AM
BUP
what exhaust set up and how are you setting up the cooling for that ?
BUP is offline
Old 01-06-2019 | 12:16 PM
Could you drill holes in the T-Stat and plug that fitting hole?
GLENAMY 242SS is offline
Old 01-06-2019 | 08:43 PM
gaffrig headers. There is a 2" freshwater inlet, and 2 maybe 3/4" freshwater outlets that feed to the headers.
chris302 is offline
Old 01-06-2019 | 08:54 PM
Could i tee it into the maniford to the right of the water neck on the manifold where the water alarm switch is?
chris302 is offline
Old 01-07-2019 | 06:59 AM
Mbam's Avatar
You could but I think it would be cleaner if you drill & tap the manifold. Looks like the boss is there.
Mbam is offline
