Sea strainer plumbing >
Old 01-19-2019 | 12:29 PM
Default Sea strainer plumbing
I am trying to figure out my sea strainer plumbing. Unclear about a few things.
I have transom mounted pickups to strainer Inlet with shutoff. Then comes something I don't get. I would be taking strainer out to the pump and pump to crossover, but for some reason, the strainers are set up with a Tee on the out side withe double 1 1/4" outlets. I don't get why two of them. I was thinking maybe they each go directly to the front engine ports but too big?
This is a twin small block Chevy setup with 2 strainers.
Also, with mercruiser pumps I suspect I need a pressure releif? I intend to run without thermostat until I find it won't work. Where should pressure relief be without and with thermostat?
I'll have a dump from the trans coolers and hope to include releif dump together with it.
Thanks for any help.
Last edited by ttrm007; 01-20-2019 at 08:35 PM. Reason: Correction - left pump out of description
ttrm007 is offline
Old 01-20-2019 | 01:22 AM
Water enters strainers on top fitting and goes to engine from bottom fitting.
The T could be for a pressure bypass or for a fresh water flush connection.
Griff is offline
Old 01-20-2019 | 01:31 PM
Strainer to crossover? Where is the sea pump in all this?
ICDEDPPL is offline
Old 01-20-2019 | 03:04 PM
Seems a little odd for hose plumbing having the strainers mounted on the transom rather than the bulkhead. Regardless I'm assuming this is a barbed T or is it threaded. Either way aside from a pressure relief is it possible the T fed direct to both left and right side of block if running an open system with no stat.
getrdunn is offline
Old 01-20-2019 | 03:10 PM
Griff had a good point also for flushing. Is there any garden hose connections near or around the bulkhead somewhere for flushing?
getrdunn is offline
Old 01-20-2019 | 04:37 PM
There is a hose fitting in top of strainer.
I'm still a little confused for sure.
ttrm007 is offline
Old 01-20-2019 | 07:21 PM
Please post pictures of yourvsetbup.
StewLow is offline
Old 01-20-2019 | 08:17 PM
Here are a few pics. As you can see in the pictures, the ends are threaded vs. barbed but I do know the hoses were actually clamped on the threads! I'm obviously changing to barbed fittings. Just trying to decide if and for what reason I need 2 on the output side.
ttrm007 is offline
Old 01-20-2019 | 08:38 PM
Just looks like someone added to suit there needs for who knows what particular reason. I'd just remove the T and replace with a 90 or what ever works out best for routing etc. Not sure if your going to install pressure relief valves or not. Personally I wouldn't bother if your running stock mags or 330's.
getrdunn is offline
Old 01-20-2019 | 08:51 PM
I'm running 652hp small block 427's. I'm thinking plumb in a pressure gauge somewhere and see if a relief will be needed once I get them fired up.
ttrm007 is offline
