ASD7m drives
ASD7m drives, complete kit as removed with all lines needed, inner plates and hardware, from prop nut to drive shaft, counter rotating, 26spline #6 style propshafts,
believed to have 63 hours since last refresh. Overall nice shape some minor corrosion and bubbling of powder coat, nothing that can't be cleaned up and recoated. Rubber boots are dry rotted from sitting. Asking 25k great deal on this setup.
What style boat did they come off, where are the drives located?, and finally, can't you get an adapter for the 26 spline so you can run other props? Thanks Dean
The boat was originally rigged with kaama surface drives, I do not believe it is a direct swap for bravo however I cannot verify. Anyone who is seriously interested please contact me directly, I have more pictures and will give any and all information I have. 7742630338. Name is Jamie leave a text I will respond ASAP.
Ugh Oh ......here we go ...... make sure to set aside 10K + for props ........
Those are the arneson bravo conversions just make sure you get the helm and the trim pumps because the are part of the kit .The only spline adapters are to go from a 19 spline to a 26 spline and if you want to run bravo type props you have to change the prop shaft.
