JL Audio Releases Next Generation Marine Loudspeaker Line >
Old 02-13-2019 | 05:03 PM
Correspondent
Correspondent
Default JL Audio Releases Next Generation Marine Loudspeaker Line
More high fidelity from JL Audio, https://speedonthewater.com/new-boat...udspeaker-line.
Matt Trulio is offline
Old 02-13-2019 | 05:21 PM
TYPHOON's Avatar
I don't need music. I have a big block to listen to. LOL
TYPHOON is offline
Old 02-13-2019 | 05:22 PM
ROB FREEMAN's Avatar
ive had my fill of jl , there digital amps suck , spend more time limp mode than they play . got three in my closet , 1200 /1 , thing wont play 5 minutes without limping .. im swapping over to wet sounds ,
ROB FREEMAN is offline
Old 02-13-2019 | 05:24 PM
cant listen to music when running , but sure enjoy the ladies dancing half naked in front of us when at the sanbar , who evers music is playing ,, I enjoy it for sure ..
Old 02-13-2019 | 06:19 PM
Surprised to hear that. As a large JL Signature Dealer that installs hundreds of digital amps a year we have not seen many issues. If installed with proper cabling and adequate battery power they are usually very reliable. If you do not want to have the issues with the digital amps the analogs versions are less effected by low voltage. Been on some wet sound projects as well. They play loud but not near the level of sound that JL has. JMO.
Double Rigged is offline
Old 02-13-2019 | 07:12 PM
My JL system has been flawless and the sound is incredible with only2 600 watt amps. My buddy has wet sounds and it’s super loud but the definition is less crisp. The tower position has a lot to do with how well the sound is projected also.
ph1971 is offline
Old 02-13-2019 | 07:23 PM
Pricing info copied from Market Insider:
M6-650X
6.5-inch marine coaxial system with 0.80-inch (20 mm) silk dome tweeters, 75W, 4 ohms
MSRP: $429.99 - $479.99
M6-770X
7.7-inch marine coaxial system with 1.00-inch (25 mm) silk dome tweeters, 100W, 4 ohms
MSRP: $499.99 - $549.99
M6-880X
8.8-inch marine coaxial system with 1.25-inch (32 mm) silk dome tweeters, 125W, 4 ohms
MSRP: $599.99 - $649.99
pp
Powerquest230 is offline
Old 02-13-2019 | 07:25 PM
M6-8IB
8-inch infinite baffle marine subwoofer, 200W, 4 ohms
MSRP: $249.99 - $279.99
M6-8W
8-inch small enclosure marine subwoofer, 200W, 4 ohms
M6-10IB
10-inch infinite baffle marine subwoofer, 250W, 4 ohms
MSRP: $349.99 - $379.99
M6-10W
10-inch small enclosure marine subwoofer, 250W, 4 ohms
M6-8FES
8-inch enclosed marine subwoofer system, 200W, 4 ohms
MSRP: $699.99
M6-10FES
10-inch enclosed marine subwoofer system, 250W, 4 ohms
MSRP: $799.99
Old 02-13-2019 | 08:28 PM
that’s just it. I baught digital for the reason of less current draw. Chit. 4 gauge at 6 feet from amp. Brand new group 31 interstates. With brand new high output alternators. If it’s power issue I’m confused. My non digital Jl amps of old slammed all day long never shut. Off or thermaled. I was a very loyal Jl fan , in excess of 15 grand being conservative. Let’s count. 1200/1. Two 750/1. Two 600 by 4. One marine , one normal. In the closet right now collecting dust. Sad but true.
Old 02-13-2019 | 08:31 PM
I must have bad luck. As I’ve sent or my dealer has sent 3 back for me in two years. Jvl replaced with new no problems there 👍👍
