Horsepower/ Speed Formula
Old 02-15-2019 | 12:42 PM
Default Horsepower/ Speed Formula
Hey Guys,
I recently came across a formula for calculating top speed/ hp and it’s been pretty accurate from running the numbers on some of my friends boats. I don’t think it’s perfect but so far is seems to get close.
Here it is:
Horsepower/Weight of Boat = X
Square Root of X = Y
Y x 250 = Hypothetical MPH.
Hypothetical MPH x 90% = True MPH (accounts for prop slip).
I’m curious to see if this holds up, especially considering the many variations in Hull Design. Post your numbers from the formula vs what your boat will actually do if you’d like.
Romeomikehotel is offline
Old 02-15-2019 | 02:16 PM
Works for my straight V bottom within a mile per hour.
ph1971 is offline
Old 02-15-2019 | 03:23 PM
Mbam's Avatar
Offshoreonly Advertiser
Take a look here
Speed Calculator
The prop slip is actually not relevant in this case. The key is having the correct constant for the boat. If you know the existing speed, weight and power you can calculate the constant. Once you have that this calculator is surprisingly accurate.
Mbam is offline
Old 02-15-2019 | 05:54 PM
Originally Posted by Mbam
Take a look here
Speed Calculator
Very good, though prop slip is still relevant. This table gives us a Constant to use based on Hull Type as well as provides more accurate prop slip numbers.
So instead of generic Yx250, we can get more specific with this table and choose the proper constant for out equation as well as adjust the prop slip portion of the formula.
Old 02-15-2019 | 06:07 PM
Default Nfw
doesn’t work for me.
Interested in my next config, testing the formula with a previous known config:
9600 lb boat (not factoring in fuel or passengers)
1200 hp
top speed actual was 68.9 mph
using the formula...
Horsepower/Weight of Boat = 0.125
Square Root of 0.125 = 0.35355
0.35355 x 250 = Hypothetical MPH of 88.38
= 22% error
242LS is offline
Old 02-15-2019 | 06:14 PM
1200 hp
= 22% error
Thats how I I initially ran the formula as well.
Take a look at the little paragraph on the Black Table above, it states that you need to use full loaded weight in the calculation. Also, you forgot to multiply by .9 to account for prop slip. I wonder if that would get you closer.
If I take your info, add 1k lbs for passenger and fuel, subtract 10% from your hp to account for drivetrain losses and then remove the 9% for prop slip, we end up at 73mph.
Still not perfect, but much closer to reality.
Old 02-15-2019 | 06:16 PM
Mbam's Avatar
1200 hp
= 22% error
I hate to say this but it sounds like there is something wrong with either the data or your setup. That boat should be much faster than that with 1200 hp.
Mbam is offline
Old 02-15-2019 | 06:23 PM
Mbam's Avatar
Originally Posted by Romeomikehotel
Thats how I I totally ran the formula as well.
Prop slip is not part of the calculation. It is in the table to give you an idea of what to expect once you have your setup right.
The variable is just that. It changes according to hull characteristics and setup. If you change to labbed props and gain 3 mph your variable will be different.
The best way to use this is to establish the variable for your individual setup. Then you can see what a change to weight or power will accomplish.
Mbam is offline
