454 Headers for TRS merctrans setup, 731 Crane cam w/114Lsa, Crane roller lifters >
Old 02-21-2019 | 06:48 AM
Default 454 Headers for TRS merctrans setup, 731 Crane cam w/114Lsa, Crane roller lifters
Building a 525SC Clone using a B&M 174. Looking for the Crane cam that's a 731 but ground on a 114Lsa with the correct lifters. Also looking for headers/tailpipes that will be close to the thru Hull location of my stock risers with Captains choice exit the transom.
bhassett110 is offline
Old 02-21-2019 | 07:15 AM
Sick Stinger's Avatar
Brotherhood #1
I should have an exhaust for your set up.
looking to keep captains call or go dry?
Sick Stinger is offline
Old 02-21-2019 | 08:48 AM
I would like to keep captains call. I am not sure if it will be safe with the 731 cam though I've herd ppl say they've not had issues and say they've had issues with reversion. I think I would be okay, but not sure. I would also like to buy the Steering from you but a the moment its one or the other. I'm selling a bunch of stuff to get both, but I believe the exhaust comes first in my case.
Old 02-21-2019 | 10:09 AM
Brotherhood #1
Post a pic of current ones. Like to make sure it will be correct.
Old 02-21-2019 | 12:45 PM
Old 02-21-2019 | 12:47 PM
Only pics I have available right now. I have the boat down to the stringers.
Old 02-21-2019 | 07:16 PM
Brotherhood #1
Only have a set of dry pipes bud
Old 02-23-2019 | 10:29 AM
Couldn't I modify the stainless riser you have to end where I need it to? If you have a different style manifold/header and the stainless riser I can fab up what I need from there.
Old 02-23-2019 | 12:06 PM
Brotherhood #1
Yes sir, didn’t know if you wanted to cut and tig it.
Old 02-23-2019 | 03:03 PM
What do you want for the setup also what brand is it?
