How much HP can a original seawaterpump mounted fuel pump take? >
Old 02-26-2019 | 04:55 AM
Default How much HP can a original seawaterpump mounted fuel pump take?
Anyone know how much HP/how many GPH a original mercruiser 454/502 seawaterpump mounted fuel pump can manage?
McNick is offline
Old 02-26-2019 | 12:15 PM
The same Merc seawater mounted fuel pump is used on the 454Mag thru the 600SC so should be good to 600hp.
I'd probably be conservative and not use it for more than about 550hp.
Griff is offline
Old 02-27-2019 | 01:30 AM
Originally Posted by ALL_IN!
600sci and 700sci same part number, so up to 700+ HP? But it's basically a priming pump for the electric pump.
The 600sci and 700sci do not use the same seawater mounted fuel pump as the carbed engines.
The 454mag thru 600sc carbed engines use part #861677T
Griff is offline
Old 02-27-2019 | 04:45 AM
Full Force's Avatar
I had them with 600 HP 565's no issues but I would not go anymore then that
Full Force is offline
Old 02-27-2019 | 07:35 AM
Doh! You are correct, sir. I misread sc, as sci. Deleting my post to prevent confusion.
Terry
ALL_IN! is offline
