Livorsi gps speedo. Antenna mod?
Bought old style livorsi speedo without antenna. Have heard that any NMEA 0183 will work. What is the type of the 3pin connector. Trying to find easyest sollution.
My speedo had the newer external antenna, but it had a lot of trouble maintaining a connection. I found the issue was with the speedo's 12V power output. I ended up wiring mine into my Lowrance GPS. Worked like a charm!
I will try this one.
https://www.ebay.com/itm/marine-ship-GPS-receiver-antenna-module-NMEA-0183-baud-rate-4800-DIY-connector/264179478915?epid=4029528096&hash=item3d8252f183:g :SksAAOSwtItbqsv6
I also saw the thread over on river daves place about the antenna you can get off amazon. Only thing holding me back is tracking down that 3 pin “molex” connector to splice to the antenna also. If anyone knows a part number or what style molex connector that is thatd be awesome. Did some searching with no luck. Hard to tell from the pictures ive seen online if it is in fact the right one
