Removing glue from fiberglass
Unfortunately, my boat is getting older. The foamed backed vinyl that is on the ceiling is starting to fall down. So I am cutting the rest of it out and got most of the foam out. Question is, how do I remove the glue from the fiberglass? Thanks
You could try one of those paint stripper wheels that go in a drill. Sorta like a wire wheel but made with flexible plastic elements. Try HD or Lowe’s. Whatever you do it will be messy. Be sure to wear a respirator.
Thanks for the suggestions everyone. I'm thinking, lay down a tarp to trap all the dust while I use the paint stripping wheel. Very light pressure to ensure I don't mess up the fiber glass.
I guess a chemical is not recommended as it may mess up the resin/fiberglass?
Matt
Matt
i am going through this right now on my stinger..... pain in the you know what!! I went the wire wheel way on my cordless drill...but i went with a metal wire wheel as i didnt feel he plastic one i was using was getting through it fast enough.....your arms hurt after a while of laying on your back and pressing on the ceiling
just have to power through it. and it hasnt hurt the fiberglass at all as far i can see anywhere.
-Wally
-Wally
Use a plunge cutter. HD or Lowes sells them. Fein tool originally designed them,now everyone makes one. I would try a curved smooth cutter. Very controllable, most tools have variable speed. Lots of different cutters available.
