32’ Trailering >
32? Trailering
32’ Trailering
Old 03-26-2019 | 12:59 AM
Default 32’ Trailering
I’m considering a purchase of a 1994 32’ with twin 450’s. I’m concerned with towing it behind my Escalade ESV, MFG (Cadillac) states 8100lbs as capacity. Anyone know weight of the 32’ with twin big blocks on a triple axel trailer? Don’t want to buy a new tow vechicle if I don’t have to ? Any ideas ?
intsol@hotmail.com is offline
Old 03-26-2019 | 08:14 AM
From what I’ve read, it seems I need 10k + capacity.
would like to hear from anyone that’s knowledgeable in this area.
Old 03-26-2019 | 08:56 AM
jadento's Avatar
I am sure someone will chime in with actually weight. But I would start with the Trailer GVW rating. That will give you a ballpark. Disclaimer - I don't recommend towing anything that weighs more than your vehicles specified capacity. But, what kind of towing? A mile or two on a local road to the ramp or 20+ miles each way with stop and go and highway? Myself and many others move 35ish foot boats(example - 35 Fountain twin 496's) with full size1/2 ton 4x4 trucks. But its only local and occasionally(hand full of times a year).
jadento is offline
Old 03-26-2019 | 08:57 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Two big blocks = minimum of 3/4 truck as a general rule.
Sydwayz is offline
Old 03-26-2019 | 09:15 AM
My 32' Fountain SFC which was a heavy model weighed 8,700 with 100 gallons of fuel. Adding a trailer puts you into the 10-11K range.
Interceptor is offline
Old 03-26-2019 | 09:20 AM
I have a 2000 32 with twin BBC and headers. 7,200LB dry weight, 130 gallon tank. Steel Myco trailer is 1800-1900 lbs.
Add fuel, anchor, life vests, cooler if you have in the boat, BS that seems to find its way in.
Any of the modern 1/2 tons with a tow package would be fine, I think the Escalde may squat more then a little and kill the air suspension.
Wildman_grafix is offline
Old 03-26-2019 | 09:22 AM
Knot 4 Me's Avatar
I'll just leave this here.
I towed a 32 Sunsation from the factory to Metro Beach with a 1/2 ton truck and needed a 12-pack after arriving at the ramp. Truck couldn't get out of its own way trying to accelerate to merge into traffic.
I towed a 32 Sunsation from LOTO to my house in Central IL (300+ miles) with my 3/4-ton D-Max and it was not until the last stoplight as I was entering town that I realized the dealership lied about making sure the trailer brakes were functioning properly (who needs brake lines to the rear calipers?!) as I had to make somewhat of a panic stop. Truck handled it just fine and the trip was a breeze.
It's not a matter of what can be done. It is a matter of what should be done to make sure you, your crew, and those traveling around you have a safe trip.
Knot 4 Me is offline
Old 03-26-2019 | 10:51 AM
Stopping your rig in a "situation" is the most important.
ALL_IN! is offline
Old 03-26-2019 | 11:24 AM
What 1/2 ton? Our buddy just got a 32 sunny ( beautiful boat BTW) and towed it home from the NE with his eco-boost with NO trailer brakes and said it wasn't bad. He has the max tow etc so just curious.
Old 03-26-2019 | 11:36 AM
bajaholic's Avatar
That falls into the : Can you, should you?, category.
I personally think with a decent trailer (meaning has good brakes) the Escalade/Suburban will do ok... However, I would recommend adding a load stabilizer airbag set up to the Escalade/Suburban. Best $300.00 you will ever spend!
But like others have stated, the bigger the truck the better.
bajaholic is offline
