Kiekhaefer controls ball bearings fell out >
Old 04-04-2019 | 07:18 AM
Default Kiekhaefer controls ball bearings fell out
So I took apart my Single Engine Kiekhaefer Controls on my 2002 Cobalt 262 to change the cables. When I pulled it apart 3 ball bearings fell out... My questions are how many are there supposed to be and where do they go?? Any pictures or advice would be greatly appreciated!
aguest7 is offline
Old 04-04-2019 | 08:35 AM
They ride on little springs and work as the detents for neutral on the shifter and the ratchety preload on the throttle,. Just look them over closely you will figure out where they go
phragle is offline
Old 04-04-2019 | 11:01 AM
Gear shifter has 1 bearing/sprin, throttle has 2 bearing/spring. structure is very simple.
JaniH is offline
Old 04-04-2019 | 08:22 PM
Thanks guys!! I will take a look at it when I get over to the boat next. Much appreciated
aguest7 is offline
Old 04-04-2019 | 09:40 PM
jeff32's Avatar
Same happened to me, if ever you dont find them back let me know, i had to special order tons of those balls and springs ! Just to replace a couple...
jeff32 is offline
Old 04-10-2019 | 08:42 AM
Wally's Avatar
Were doomed!
Look here at parts 21 and 22
https://www.mercruiserparts.com/bam/...32079/8457/285
-Wally
Wally is offline
