Exhaust Shutters
Old 04-07-2019 | 08:37 AM
Default Exhaust Shutters
Which exhaust flaps are good for a through hull where I cannot get to the outside? My boat has the silent thunder exhaust that blows through the boarding platform and the flaps are burned away. There are loosely mounted vertical shafts in the 3 1/2" ID thru hull tubes that are on some riveted mounts. I'll do some looking, but if anyone has ideas I'm open to suggestion.
NHGuy is offline
Old 04-07-2019 | 08:11 PM
Skip this, I found some that will do.
NHGuy is offline
Old 05-01-2019 | 09:13 AM
Do you have captains call exhaust?
01Sea is offline
Old 05-06-2019 | 11:20 PM
BUP
Mercruiser actually recommends using both - internally and external flappers
BUP is offline
Old 05-07-2019 | 05:39 PM
I have changed them grind rivets off instLl mew. They where available a few years ago
oconnor marine is offline
