pan gasket MK IV >
pan gasket MK IV
pan gasket MK IV
Old 04-13-2019 | 02:59 PM
F-2 Speedy's Avatar
Default pan gasket MK IV
Im working on a couple MK IV Bowtie 10.2 engines, I ordered Felpro 1884R and the front and rear sealing area seems to be to thick, the pan rocks back and forth and the rails are about 1/4 inch from the block, are these the correct gaskets ?? they look to be stock mercury pans that someone but a wider bottom on them for oil capacity.
F-2 Speedy is offline
Old 04-13-2019 | 06:33 PM
I just fought with some felpro one piece gaskets and the cast aluminum MerCruiser pans. The thick pan gaskets were too thick I was breaking bolts trying to smash it down, and the thin ones were just a little too thin. I ended up using the thin ones with a good layer of ultra black, tightened the bolts up 50%, let it set up, then tightened the rust of the way. No leaks yet.
sailtexas186548 is offline
Old 04-14-2019 | 08:59 AM
F-2 Speedy's Avatar
ttt
Old 04-14-2019 | 04:58 PM
F-2 Speedy's Avatar
All you guys running MK4 blocks and no answers ??
Old 04-14-2019 | 05:49 PM
GPM
The gasket sets I used in the past came with 2 sets of the rubber end seals, thick and thin. I don't remember the part number but they were Fel Pro.
GPM is offline
Old 04-14-2019 | 07:22 PM
F-2 Speedy's Avatar
there has to be a 1 piece made for these blocks ? Fel Pro OS30061T ??
Old 04-14-2019 | 11:16 PM
i no longer use the one piece gasket for mark 4 engines,i have had several leak and that sucks.when you install the rubbers on the 4 piece gasket make sure to get the rear one pushed all the way down into the rear main cap and always put some sealer in the groove first.i always apply a smear kote of the right stuff on both above and below the gasket.hope this helps.edit in,speedy,don,t use the standard pan gasket on those 572s,fel pro makes a nice one fitted for a stroker pan.
mike tkach is offline
Old 04-15-2019 | 08:19 AM
F-2 Speedy's Avatar
Do you have a part # or are you saying go back to the 4 piece ? Ive ordered one that looks to be notched on the inside in between the bolt holes to match the block, is that what you mean
Old 04-15-2019 | 09:12 AM
yes use the 4 piece.i will post the part number a little later today.
Old 04-15-2019 | 11:01 AM
fel pro 1893 is the gasket that is correct for engines with stroker pan.it is a 4 piece gasket.
