Mercruiser carbs >
Mercruiser carbs
Mercruiser carbs
Old 04-21-2019 | 09:49 PM
Question Mercruiser carbs
Hi Larry here, I am ew to this sight, I am looking for two MERCRUISER 525 SC EM CARBS, IE 1050 DOMINATOR. Does anyone know where to find?
LJR1966 is offline
Old 04-22-2019 | 12:19 AM
There is really nothing that special about them. They are 1050's with #98 jets(rich) all around and 6.5PV's
Griff is offline
Old 04-22-2019 | 06:35 PM
Nothing special, Aren’t they Blue 😄
1BIGJIM is offline
Old 04-22-2019 | 06:45 PM
SB
2 circuit if I remember correctly.
SB is offline
Old 04-22-2019 | 08:45 PM
yes they are blue. does anybody know what number air bleeds are used on primary and secondary also pump cc? what color are the accelerator pump cams on primary and secondary? looking for OEM carbs.
LJR1966 is offline
Old 04-22-2019 | 10:22 PM
Rookie's Avatar
The cam is a Crane #132561
Specs are 228/236 .530/.551 on a 114 lobe sep.
The ignition timing curve is set up with 13* base timing and 22* advance. It advances to 25* by 2000rpms and then gradually advances up to full advance of 35* by 4500rpms.
Carb is a 1050 dominator
Jets are 98's all around--I think(Holley #122-98)
6.5 PV's front & back
#35 Acelerator nozzles
50cc acc pumps front & back
Acc pump cams-frt& rear--white-use # 1 hole.
Boost is set at 5.5# stock with a 2:1 ratio
Pistons are forged TRW #L2453
Valves are 2.19/1.88
Rookie is offline
Old 04-23-2019 | 08:21 AM
Thanks great info, what are the air bleeds for the idle circuit and primary and secondary circuits.
LJR1966 is offline
Old 04-23-2019 | 07:19 PM
LJR1966 is offline
Old 04-23-2019 | 11:12 PM
I'm not sure.
I pulled those specs out of a 525SC Merc factory service manual years ago when I posted them. I gave the manual to the person I sold the boat to.
And yes, they were 2 circuit carbs but used a 3 circuit bowl gasket, if I remember correctly.
Griff is offline
Old 04-25-2019 | 07:09 PM
hi does anyone have these oem 1050 dominator blue holley carbs for the 525sc motor laying around thanks ljr
LJR1966 is offline
