XR Outdrives vs. XZ >
XR Outdrives vs. XZ
XR Outdrives vs. XZ
Old 10-31-2002 | 05:37 PM
Default XR Outdrives vs. XZ
I have heard that using an XR drive instead of an XZ cost you a mile per hour or 2 on top end. Any truth to this? Also, I am hearing that there a lot of problems with the XR's blowing out seals. This concerns me and I am just asking for opinions or actual experiences good or bad. Thanks
Steet is offline
Old 10-31-2002 | 05:45 PM
merlin540
my 31 ao has twin 970 hp blower motors on xz 1.36 bravos with 60 hrs on the pin. no problems yet. i run it hard
Old 10-31-2002 | 06:11 PM
rhino
Their is a new retainer available for XR/XZ that eliminates the seal problem. It is now in the EPC so local dealer should be able to look it up or just call "Lake X". HP loss in XR (straight gears) is minimal. XZ is much quieter though not quite as strong. 970 is way too much power for any factory Bravo. It takes a very good throttle to make it last. If you can afford the "large chunk of change" the VI drive life can be measured in four digits. Dry sumps are megabucks but they consume LESS HP than Bravo's (FACT) and way out last Bravo's. Add up cost of rebuilding over-powered Bravo's compared to a Mercruiser VI not to mention headaches and tow charges. How many broken VI headaches have you heard out lately! It's very rare. Bravo's are wonderful drives but never meant to take some of these crazy horsepower numbers.
Old 10-31-2002 | 06:19 PM
Mbam's Avatar
Offshoreonly Advertiser
What Rhino said. We do have the seal retainers on the shelf. PN is 11-841026A2, we sell it for $52.34
Mbam is offline
Old 10-31-2002 | 06:34 PM
Dock Holiday's Avatar
Charter Member #34
Steet,
70 Hours on the XZ's behind the 500's this season and no problems.
Ken with the 38 Fountain, 575's did blow a seal just a couple of months ago on his XR's. I think this is the first problem he has had like that.
Mark
Dock Holiday is offline
Old 10-31-2002 | 07:01 PM
Why would the XR be more likely to blow seal than the XZ ?
h2owarrior is offline
Old 10-31-2002 | 10:13 PM
Mr Gadgets's Avatar
Charter Member #601
supposedly the straight cut gears create more pressure and heat.. so stuf moves around more..
Anyone have a seal retainer, with the ridge, that will fit a standard Bravo housing? I know Max Works does..
Any info would be appreciated..
Dick
Mr Gadgets is offline
Old 11-01-2002 | 12:55 PM
KAAMA's Avatar
Originally posted by merlin540
...on the pin.
Does that mean the pinion shaft or gear or what? please be extremely specific. thanks
Mark/KAAMA
KAAMA is offline
375stinger
0
01-23-2006 04:01 PM
Nauti Kitty
2
05-22-2005 07:44 AM
Excalibur
36
11-10-2004 10:03 AM
Von Bongo
10-12-2004 08:27 AM
CFD12
05-07-2003 10:20 PM
