496 key on beep >
496 key on beep
496 key on beep
Old 04-26-2019 | 01:39 PM
Default 496 key on beep
Last summer the single beep when I turn the key to the on position was random if it worked or not. It would always start up fine and did not have beeps while running. I put 12+ directly to the horn and it works, I have also checked continuity on the purple and tan/blue wires that goes to the horn, from the key to the cannon plug and all checks out OK on the 'boat' side of things. I know the horn sounds when the tan/blue is grounded, either from a fault code, low drive lube or low oil pressure, All while the motor is running. And the purple has 12+ whenever key is 'on'. My question is, what grounds the tan/blue wire when the key is turned to the on position for a quick 'beep'?
chartersj is offline
Old 04-26-2019 | 07:15 PM
muc
The PCM provides the ground for the horn.The drive lube and low oil also go thru the PCM.
muc is offline
Old 04-30-2019 | 11:27 AM
BUP
and the warning horn as to be hooked and working as well.
BUP is offline
Old 04-30-2019 | 11:54 AM
I traced the tan/blue from the male side of the cannon plug and it goes to the pcm as you said. It sounds more like a bad/loose connection then something wrong with the pcm? I verified the horn works and have continuity from the horn to the pcm...also power from the ignition to the horn. I will be putting my motor back in soon then I can see if the drive lube monitor will sound the horn every time or not
