What part number for EST distabutor for marine (voyager) >
Old 04-29-2019 | 01:46 PM
Default What part number for EST distabutor for marine (voyager)
What part number for EST distubutor for marine (voyager). It was used with est dist and carbs. I have the wrong module I need the marine one that has advance build in to it. when running stand alone distributor.
thx
cyrus77 is offline
Old 04-29-2019 | 02:36 PM
SB
GM#10482830 /AcDelco # D1965A
Get heat transfer compound and us it correctly...super thin w/razor blade. The clear gel that comes with most aftermarket and oem is silicone, which is not a heat transfer compound. you can get arctic Silver or equivalent from local computer repair stores or Amazon, and Mercruiser also sells their own real transfer compound separately.
SB is offline
Old 04-29-2019 | 02:42 PM
SB
BTW, the correct module has a super quick advance rate which most people erroneously think is defective. It adds 10-12* at 750rpm
So...some think it only adds 10-12*F, since they don't see the first 10-12* LOL. Do a search here on OSO, I have put the actual advance curve up several times, as I'm sure others have too.
SB is offline
Old 07-16-2019 | 11:38 PM
delete
cyrus77 is offline
