Where to dump excess water? >
Old 04-30-2019 | 11:30 AM
TomZ's Avatar
Default Where to dump excess water?
My port motor is back in the boat, and I’ve installed water pressure relief valves to prevent seepage past the outer head gasket seal. I’m trying figure out where to dump the water, and have come up with these choices:
1. Install 3/4 thru hulls in the transom and dump out the back.
2. Add two more 3/4 thru hulls next to the bilge pump thru hulls on the starboard side (advantage is that I can see them in operation, but that side is already busy with outlets).
3. Connect into the junction of my headers/tail pipes (can that even work?).
Suggestions are appreciated! Thanks!
TomZ is offline
Old 04-30-2019 | 03:37 PM
The less holes in the transom the better. go out the side .
ICDEDPPL is offline
Old 04-30-2019 | 03:39 PM
TomZ's Avatar
I think that's the direction I'm leaning.
TomZ is offline
Old 04-30-2019 | 05:55 PM
cigrocket's Avatar
Mine go out the side on the Playboy Boat. You can see them working. When I had the white top gun I dumped the inter cooler water out the transom directly on top of the 3A Drives. Instant Drive Shower and Cooler. Just a thought.
cigrocket is offline
Old 04-30-2019 | 06:34 PM
If it's not through wood the stern is just as good as the side.
f_inscreenname is offline
Old 04-30-2019 | 08:40 PM
Tinkerer's Avatar
I dump mine out the back of the standoff box onto the top and sides of the drive upper housing.
NO chalk on my drive.
Now I just need to rig up a setup to spray water on the sides of the lower to keep the lower housing cool.
Tinkerer is offline
Old 05-01-2019 | 06:49 AM
You could aim this at the lower
AusScarab29 is offline
Old 05-01-2019 | 10:42 AM
TomZ's Avatar
Thanks guys.
I'm going to add them to pair that are handling the bilge pumps. I really didn't want to drill into the transom.
TomZ is offline
Old 05-01-2019 | 11:02 AM
TomZ's Avatar
One quick add-on question... by lowering water pressure, will the motors be at risk of developing steam pockets? Never an issue it seems (head gaskets looked great, and no scoring or other concerns on cylinder walls), but wanted to ask. I've added the pressure relief valves because I had strong evidence of seepage past the head gaskets on the outsides of the block (both motors).
TomZ is offline
Old 05-11-2019 | 02:17 AM
Rhythm and Blues's Avatar
Originally Posted by TomZ
Thanks guys.
tapping into the bilge pump hoses?
Rhythm and Blues is offline
