525EFI cam sensor
i have not seen a 525EFI oil pump drive/cam sensor in person, but by pics it looks just like the one from the 98-99 454 Pick Up trucks.
GM #1104068 / AcDelco# 213-350
If I am right for some reason,it is only $54.56 from Amazon
Here are the pics of the Delco one:
Remember, do your homework with the above since I don't have either in my hands.
Also remember, any distributor/cam gear should have a moly lube or etc packed in the gear teeth for proper break in. I use Redline assembly lube because I have a bunch.
SB if he has the second half engine serial breaks then the hp 525 does not use that
As most know I have scream engine serial number a must up here in the 1000s of times. This will determine parts and procedure installs for the OEM marine engine, Year model especially year model of the hull means nothing ZERO for marine engine
Here number 12 is a cover because it used the cam sensor in the timing cover Over half the hp 525 did not use the intake manifold cam sensor .
MerCruiser Race Engine & Drive 525 EFI Intake Manifold & Components Parts
# 29 cam sensor engine serial number important to what you have ?
MerCruiser Race Engine & Drive 525 EFI Engine Components (Water Pump & Front Cover) Parts
