Adding a pad
Old 05-07-2019 | 10:23 AM
Default Adding a pad
Has anyone added a pad to their v hull or made the chines/ lifting strakes bigger . Im contemplating adding a pad for more lift an speed on a 28 pantera ???
cheers gerry
gerrypantera is offline
Old 05-07-2019 | 10:43 AM
Peter Unwin from England is adding a pad to his Coyote. He is on here once in a while but I can't remember his screen name. Has a 29OL on this side of the pond he put a carbon stabilizing "tail rudder" on it. Does a lot of out of the box ideas, he has also added a lifting wing to the front of the Coyote.
Wildman_grafix is offline
Old 05-07-2019 | 10:44 AM
cheers gerry
Probably possible. Would be easier to sell and buy velocity, hustler, fountain, activator, kryptonite, superboat, progression, phantom etc etc
hogie roll is offline
Old 05-07-2019 | 10:53 AM
SB
I also believe the guy who set out to have the worlds fastest 22 Donzi went to a pad. I believe there are some write ups and videos around here (OSO) ofthem somewhere,
edit in.
Here is his U Tube Page
Björn Carapi
https://www.youtube.com/channel/UCJ5...=dd&shelf_id=0
SB is offline
Old 05-07-2019 | 11:29 AM
I’m adding a pad to my 25’ Checkmate.
Twin O/B Sonic is offline
Old 05-07-2019 | 11:55 AM
Thinking about doing a notch , no pad on my 31 since I am going to a SSM V. Thinking 8" up and 8" deep. Would be a pretty forward task for me since I am just about done gutting. My thinking was to build a plug with a 24 degree and that 8" x8" dimension and build part, cut out the hull and bond together with the new stringers.
open87 is offline
Old 05-07-2019 | 03:52 PM
Go for it! Especially if you like your Pantera. I have seen catamaran sponsons modified with a flat running surface.
bulletbob is offline
Old 05-11-2019 | 02:33 AM
there should already be a pad on the mate
miller high life is offline
Old 05-11-2019 | 06:23 AM
Too much vee to do what I want it to.
Old 05-11-2019 | 10:03 PM
Check out the pad on a tuff. Perfectly flat aside from a chine down its center. They fly
