Go Back  Offshoreonly.com > Owners Forum > Excalibur
31 excalibur restoration >
Old 05-07-2019 | 02:08 PM
Default 31 excalibur restoration
I am now starting to begin my excalibur project. Its a 1978 NAP hull. I think its kevlar hull but still trying to confirm. Boat is in very good shape for its age and will be getting a pair of old school 420hp 454s and trs drives. Working on stripping the hull now and will do a complete rerig/ rewire. Im sure ill have lots of questions as i go!
cant seem to post pics...
St.clair85 is offline
Old 05-07-2019 | 03:13 PM
Make four more posts and you'll be able to post pics.
payuppsucker is offline
Old 06-15-2019 | 05:37 AM
Turns out boat will need a new transom. I am now trying to decide if going to bravo while im doing it is a better choice. I have access to 2 gimbals and 1 drive already. Anyone ever change one to bravo? I know zaine did but he doesnt post anymore
Old 11-22-2020 | 11:25 AM
Are you still working on this restoration?
Markd426 is offline
Old 11-22-2020 | 02:28 PM
Yes i am. Been slow going as work and life has been busy. I got the transom out, engine stringers and bulkhead too. Once the new bulkhead, stringers and transom are done i am going to paint the hull and deck as close to original as possible.
I have aquired 2 bravos, transom assemblies, offshore mounts, k planes, marine machine full hyd steering, zero effort controls, new gauges, lighting, wiring harnesses, drop out bolster seats, various rigging components. I have almost everything to build a pair of nice 454s i just need to decide on cams.
Its been lots of work so far with plenty more to go. Hoping to have it out in 2021
Old 11-23-2020 | 09:19 AM
Why not go wit a lighter LS motor setup to get the same or more HP? I I keep my cursed 38' the 541s are coming out and 2x LS7 motors are going in.
Barnacle Bill is offline
Old 11-23-2020 | 12:31 PM
I am also repainting the deck in mine this winter... pulling the motors and doing a mild build. Still looking at cam choices as well. If you went with aluminum heads, intake and exhaust manifolds with the weight savings going to the bravo you could be pulling close to 500 lbs off the back of the boat
Markd426 is offline
Old 11-23-2020 | 08:15 PM
Let us know how that works for you and the cost to make it all happen.
Old 11-23-2020 | 08:22 PM
Post some pics id love to see your boat. I have aluminum intakes and alum 496 exhaust manifolds, and the bravo conversion.....plus all the rotten soaked wood is now gone. She will be much lighter and stronger then before. Im not spending the money on alum heads or anything yet. Ill get a few seasons out of these and upgrade as i need/ want to. Main focus is getting it back to an operating boat. Long ways to go!
Old 11-23-2020 | 08:25 PM
getting the hull stripped and rotten wood removed
