Slow trim pump? 87 Formula Mercruiser Alpha
Howdy!
I have an 87 Formula with twin 350s. One trim pump works great. The other moves REEEAAAALLLLY slow. I am concerned the electric motor is burning up, due to it not making the noise the other does, and its slow movement.
Can anyone give me some advice on h0ow to test it, how to ID the pump if I need to rebuild or replace, and where I could find parts?
I really appreciate the advice. I am not adverse to taking her to the shop, but noone here really wants to work on it.
As stated earlier clean all contact points and check wires for corrosion. I did put new brushes in 2 of those pumps before and solved my problem. I believe it was the crud in the motor more so than the new brushes. Not a fun job, I would buy a new motor off eBay if I had to do it again.
Trim motor wearing out and or possible valve body issues. Also check the condition of the fluid and if you have water in it. That unit has not been made in many years so father time has taken over. Its most likely time for some new parts or a new complete current unit.
