Engine mounts
Old 05-20-2019 | 07:18 PM
Default Engine mounts
are these engine mounts ok for 850 hp big block engines?
Are these style mounts ok for 850 hp engine?
cdowjr is offline
Old 05-20-2019 | 07:58 PM
SABER28's Avatar
easy answer? NO
SABER28 is offline
Old 05-20-2019 | 09:36 PM
Tinkerer's Avatar
I am running the upper half but solid bottoms on 800 + HP
But my boat doesn't jump out of the water much.
Tinkerer is offline
Old 05-20-2019 | 10:03 PM
alot of hp into a stud..........
it would work
but is it the best way ......no
flashgordon is offline
Old 05-20-2019 | 10:58 PM
SABER28's Avatar
the problem is the lag bolts that go into the stringers
SABER28 is offline
Old 05-21-2019 | 01:57 AM
I would not use those in anything over about 450hp unless you bolt them to something like this
Griff is offline
Old 05-21-2019 | 08:19 PM
Tinkerer's Avatar
The stringer mounts on mine are bigger than that.
Tinkerer is offline
Old 05-22-2019 | 03:36 AM
Do you have a photo
AusScarab29 is offline
Old 05-22-2019 | 08:26 PM
Tinkerer's Avatar
not really = not handy
They are just bigger
again my boat is a cat so it doesn't jump big waves like my Scarab did.
But I had the same mounts on my Scarab without any problems.
I solid mount my engines. The mounts on my Daytona don't have any rubber.
That and I have the rear mounts locked down so the engine can't twist or move.
Tinkerer is offline
Old 05-23-2019 | 12:13 AM
BUP
the feet walk even on the stringer mounts Grif posted. The torque of the engine is one of the contributing factors. - Rough water is another, also harmonics of the engine and so on. The bigger the torque of the engine the worst it is on the feet -
Feet = what the OP posted in the pic
BUP is offline
