First Mistake Of The Season >
Old 05-25-2019 | 03:37 PM
Default First Mistake Of The Season
Put the muffs on started the port motor & no water coming out the exhaust. Well then I hear the squealing. Thought @ first it was a dry pulley bearing or alternator belt noise. Then I realized it was pump impeller. Well needless to say I shut it off & sure **** pump housing was smoking hot. Well I thought you dumb **** why didn t you prim it first & this wouldn t of happened. So I got smart and primmed the starboard motor. Filled it to the top until I heard it running out the drive to the concrete. Fired it up with the muffs engine idling, & it would not pump water out the exhaust until I forced the muff by hand tight to the drive for like a minute & then it finally pumped. WTF, anyone else have this experience? On my old boats I never even ran muffs I ld just put it in the water & ran it but then again I was not so smart back then & apparently I still not smart.
So I see there is no longer an impeller in the out drive. This is a 28 Formula with a pair of 350 mags,2006. @ first I thought that was the issue but come to find out thats not it. So again WTF? I m thinking no body primes blocks now a days? But I think its a must or you will be replacing pump impeller's yearly. Any body have some
in site on my dilemma? Lost the whole fricking Memorial weekend. Signed one pissed off guy.
drumerjb is offline
Old 05-25-2019 | 06:00 PM
I replace impellers yearly no matter what. But to each his own. That sucks though.
Crude Intentions is offline
Old 05-25-2019 | 08:42 PM
SABER28's Avatar
yes the impellor is just bad enough not to have enough suction. they sure dont seem to last anymore.
SABER28 is offline
Old 05-25-2019 | 09:02 PM
Do you prime yours every year or not?
drumerjb is offline
Old 05-26-2019 | 12:42 AM
I had a problem with my muffs skating forward with the water on and eng off. By the time I climbed in and got the eng started, the muffs skated far enough to partially expose the holes. Connected some safety wire to the muffs and wrapped it around the back of the drive so they couldn't skate forward, no more impeller squealing.
zz28zz is offline
Old 05-26-2019 | 01:20 AM
BUP
all impeller changes are 2 years max and worse if you do not use your boat - Impellers sitting they form a set. Just like your car tires that have not moved in months - they get a flat spot.
Impellers fold over in one section of the housing they sit in and will not prime very good upon zero movement for months -- for a jist.
Anyways at the beginning of the boat season every season its best to install impellers regardless what one thinks. Its a piece of mind and your volume of water flow is back like how it should be unless you have issues in the cooling systems elsewhere. Many used boats can develope other cooling issues as well. ie boaters whom never change out water circ pumps and t stats think they last 4 ever. is 2 great prime examples.
Anyways if one has side feed water pick ups for their outdrive apps === your best muffs on the market are in the next post. I have posted this before about the best water muffs to use. Been using these exact muffs for about 20 years to current. For all Merc and the newer Volvo apps.
BUP is offline
Old 05-26-2019 | 01:23 AM
BUP
side water picks ups. these will never move and aid in water flow using the water hose to run the engine
BUP is offline
Old 05-26-2019 | 01:43 AM
BUP
next info is you most likely have Mercruiser engines and Bravo 3 for outdrives and that means you will have the brass junk Gen VII water pump assembly and that junk brass housing that scores up badly. Another reason why you did not prime water.
I have the fix kit for the scored GEN VII pumps for 50 bucks shipped
BUP is offline
Old 05-26-2019 | 09:09 AM
good to know,,I hate working on those pumps,,they suck.
sutphen 30 is offline
Old 05-26-2019 | 10:15 AM
Yeah, supposedly the pumps had been replaced just prior of my purchase. Didn't know about brass housings thought they were all cast steel.
As far as that style muff goes if they don't leak and you have 60 pounds house water pressure ,how could it not supply water throughout the block?
As long as the impeller is spinning water is going to get through out the block. But you definitely have a great point that impeller housing is oblong for lack of better description and like you said the impeller is bent over more on half of the side of the housing versus the other side of the housing and it will set and not want to go back to its natural position from sitting.
Problem I'm up against right now is I can't get down in the bilge to remove the pump assembly and I don't know if anybody can get in there unless they're very small person I think I might have to pull the freaking motor to replace the pump
drumerjb is offline
