Stallings extension boxes- can it go straight shaft? >
Old 05-25-2019 | 09:03 PM
Default Stallings extension boxes- can it go straight shaft?
Lot of extra stuff in these things. Can I just get the longer imco shaft and get rid of the extra bearing and u joints? Anyone done it? Any reason it wouldn’t work?
tmmii is offline
Old 05-25-2019 | 09:14 PM
Tinkerer's Avatar
Yes
Tinkerer is offline
Old 05-26-2019 | 07:24 AM
When the box is installed in the top holes, it’s neutral, o raise
JaayTeee is offline
Old 05-26-2019 | 08:35 AM
I went straight long shafts on my boat.
sutphen 30 is offline
Old 05-26-2019 | 08:48 AM
what height did you go with?
tmmii is offline
Old 05-26-2019 | 09:06 AM
I redid the back of my boat,so I went w/ 0/neutral and raised the x dimension per Richie Sutphen's recommendation.Prop shafts pretty level to the bottom of the boat.
Old 05-26-2019 | 09:26 AM
Think it would work if I went up 2”? Hard to see any type of angle through the access holes.
tmmii is offline
Old 05-26-2019 | 09:58 AM
You can see the middle set of mounting holes with the access covers removed pretty easily, if the bolts are in the bottom hole, they’re up 2”, middle hole 1” up, top hole neutral 0 up
JaayTeee is offline
Old 05-26-2019 | 11:04 AM
I’m taking them off of one boat and plan on installing them on another boat in the 2” hole.
tmmii is offline
Old 05-26-2019 | 10:11 PM
If you want to run a straight shaft and be up in the bottom hole( 2” up) you’ll need to raise the engines 2”’s
JaayTeee is offline
