Engine Cutting out >
Engine Cutting out
Engine Cutting out
Old 05-27-2019 | 01:50 PM
gripit's Avatar
Default Engine Cutting out
Hi, I have a 1988 420 HP and the engine cut out today. The engine is getting fuel. It has thundbolt IV and Accel Super Shock Coil. I came back on one engine and when I got back I hit the reset braker and the engine started for a couple min and cut out again. The only thing I did to the engine this year was to change out the MerCruiser Water Temperature Sender. Could a bad temp sender cut the engine out? Please advise.
gripit is offline
Old 05-27-2019 | 02:35 PM
Tinkerer's Avatar
Did the button click when you pushed on it?
If it did than you have a short or overload somewhere that is blowing the breaker.
IF you don't understand DC power systems get someone involved that does. You don't want to burn up the boat.
Tinkerer is offline
Old 05-27-2019 | 03:08 PM
gripit's Avatar
It didn’t click. What else could it be?
gripit is offline
Old 05-27-2019 | 04:23 PM
A temp sender normally wouldn't keep a motor from running. Guess the press of the breaker was just coincidence.
Need to know what is missing. Your need air, fuel and spark, and appears you have fuel and air, so check for 12V on the coil when the key is ON
AllDodge is offline
Old 05-27-2019 | 05:05 PM
you need a mixture of fuel and air in a burnable amount,you need spark at the correct time and the mixture needs to be compressed in the combustion chaimber.now find the missing part.
mike tkach is offline
Old 05-27-2019 | 06:12 PM
gripit's Avatar
How about batteries and alternator? Once the engine is started if it has a weak battery could that affected it in anyway? I was always taught the battery is only used to start . Once started the alternator will run the engine and charge the battery. Is that true?
gripit is offline
Old 05-27-2019 | 07:40 PM
check to make sure your not losing 12v on the purple ignition wire. Check your ignition switch and the 9 pin cannon plug for connection problems.
kvogt is offline
Old 05-27-2019 | 07:45 PM
Ignition switch ????
gofastboater is offline
Old 05-29-2019 | 01:07 AM
Accel Coils are junk IMO.
Its a 1988 carb engine and pretty simple. It needs spark, fuel and air with the correct timing.
Griff is offline
Old 05-29-2019 | 06:05 PM
gripit's Avatar
Hi, now I can't get the engine started. Its so simple but I can't figure it out. I have fuel, the motor is turning over but won't run. It seems like its trying but just never turns over. So is it the Accel Coil, Thunderbolt Ignition or distributor cap? Please help. Its pissing me off! LOL
gripit is offline
