Can anyone give me some guidance on putting Safety's in the Holley HP system? >
Old 06-01-2019 | 08:50 AM
Default Can anyone give me some guidance on putting Safety's in the Holley HP system?
I figure for Oil pressure, temp, etc.
Thanks!
cyrus77 is offline
Old 06-02-2019 | 03:02 PM
articfriends's Avatar
Up and running yet?
articfriends is offline
Old 06-03-2019 | 03:49 AM
Have you got it setup yet?
AusScarab29 is offline
Old 06-05-2019 | 12:36 PM
Yes
cyrus77 is offline
Old 06-06-2019 | 04:03 AM
Are you happy with Holley HP system?
what engine do you have it on
Old 07-01-2019 | 07:36 AM
Old 07-01-2019 | 01:48 PM
Yes great system. Very happy. jsut want to added fail safes.
cyrus77 is offline
Old 07-01-2019 | 09:25 PM
I haven`t gotten into the software portion but just a quick look .. isn`t it in here? somewhere ??
ICDEDPPL is offline
Old 07-02-2019 | 07:41 AM
That will give you a rev limit of approximately 2600 rpms. Once you pull the sticks back or input trigger clears it resets.
kvogt is offline
Old 07-04-2019 | 09:40 AM
My goal is make the engine idle/warn if
water temp exceeds 190
oil pressure less than 10 psi at idle
oil pressure less than 20 psi at 2000
oil pressure less than 30 psi at 3000
​​​​​​​oil pressure less than 40 psi above
​​​​​​knock sensor above x pull xx degrees of timing
limit RPM to 1500 is fuel pressure is below 35 psi
Limit RPM to 1500 if coolant is below 140
Warning if the voltage is less than 13V and RPM is above 500
and anything else you guys can think of, I am open to.
cyrus77 is offline
