02 575sci which one is the oil temp sensor >
Old 06-02-2019 | 07:14 PM
Default 02 575sci which one is the oil temp sensor
bajaboatnut is offline
Old 06-02-2019 | 08:20 PM
BBYSTWY's Avatar
The one on the left is the knock sensor...the one on the right under the one you circled that looks like a little canister should be oil pressure so the one you circled on the right should be oil temp
BBYSTWY is offline
Old 06-02-2019 | 08:34 PM
It’s the one clear to the right that isn’t circled, above the oil filter adapter
JaayTeee is offline
Old 06-02-2019 | 08:42 PM
BBYSTWY's Avatar
Didn't see that one...good call
BBYSTWY is offline
Old 06-03-2019 | 01:01 AM
BUP
that is correct
BUP is offline
Old 06-03-2019 | 01:11 AM
What they said ^^^^^^^^^
The green circled one is the oil psi sender and the wire for it is not visible and on the bottom of the silver canister.
It is T'd together with the oil psi alarm sensor which has the tan/blue wire.
Griff is offline
Old 06-03-2019 | 08:45 AM
Thank you guys for the help. Going to be tight replacing it.
Old 06-03-2019 | 12:51 PM
BUP
^^^^^ if you are changing your oil temp sensor out, would you mind sending me your old one to Texas because I am having all TEMP related sensors that are on marine engines made in the USA and better quality along with better accuracy currently. .THANKS
BUP is offline
Old 06-05-2019 | 09:57 AM
i thought the oil pressure sensor is that big ass canister off the bottom of the sensor circled in green
i have a manual at home and can look after work
LTZCrew is offline
Old 06-05-2019 | 05:46 PM
it is, the OP was asking about the oil temp sensor which is to the rear of that
JaayTeee is offline
