88 7.4 Oil Change >
88 7.4 Oil Change
88 7.4 Oil Change
Old 06-08-2019 | 02:20 PM
Default 88 7.4 Oil Change
Hello All,,This is my first oil change I my boat I bought last fall..I bought one of those Sure-Flo pump/bucket units,,but the tube wont go down the dip stick tube
Anyone know if the Pachanga 22 w/7.4 had a tube or something under the engine to drain oil..I ran out of time yesterday on it,,looking for some info on draining this oil.
Thanks!!!!!
MnFun22 is offline
Old 06-08-2019 | 03:02 PM
BUP
oil drain hose kit at your oil pan drain plug installed is your best option.
BUP is offline
Old 06-08-2019 | 04:41 PM
Thanks!!!!!
Use a piece of gas line (thick wall like USCG Type A1 marine line) and connect it to the top of the dip stick tube with a hose clamp. Get rid of the skinny tube and connect the other end of the gas line to the pump. Do have the motor run a little bit to heat up the oil a little (5 minutes or so), no need to get it hot
AllDodge is offline
