proping an 89 flat deck >
Old 06-19-2019 | 11:51 AM
F-2 Speedy's Avatar
Default proping an 89 flat deck
The boat in an 89 TG with notch transom, is 575-600 hp enough power to spin 28 4 blades to 5000-5200 ?
F-2 Speedy is online now
Old 06-19-2019 | 11:57 AM
14 apache's Avatar
that might be tuff one. Maybe a little heavy on pitch.
14 apache is offline
Old 06-19-2019 | 12:05 PM
F-2 Speedy's Avatar
kinda what I was thinking, It has 23's on it now and reving to 6k+, maybe a mirage 25 + 3 blade ? engines are 580's dart intakes and 1100 dom's
Old 06-19-2019 | 12:09 PM
14 apache's Avatar
  1. is it going high 70s
Old 06-19-2019 | 12:35 PM
F-2 Speedy's Avatar
He's not sure no speedo working in the boat, Id guess 68-72 but just a guess, I'm just trying to get the rev's down and pick up a little speed
Old 06-19-2019 | 12:46 PM
14 apache's Avatar
33 Apache I had did 68mph at 5400rpm boat weight was 8600lbs might want to try 4 blade 24 pitch
Old 06-19-2019 | 12:49 PM
F-2 Speedy's Avatar
Thanks, I asked him to down load a gps speedo app on his phone and give me some numbers next time he's out............I'm thinking his boat is around 10K
Old 06-20-2019 | 01:05 AM
A 38 Flatdeck will be around 11k dry. It will depend on the hp/torque curve of the engines as to how to prop it.
I would say to try going up 2-3 inches in pitch to start. I doubt he would be able spin the 28 Bravos to 5000rpm.
Griff is offline
Old 06-20-2019 | 05:10 AM
Full Force's Avatar
Top gun will weigh around 9800-10,000 with light to no fuel, what drives?
That HP with TRS?? your looking at worked 25 Mirage plus or 24 Hydromotives spinning 54-5600 range, or a 24-26 Bravo around 5200 speed should be 74-77 ish depending on actual HP it has and conditions.
If Konrad boat with 600 HP a 26 Bravo1 will spin 5200@ 73 mph or close to it. or a 28 to 5000rpm at 71mph
Full Force is offline
Old 06-20-2019 | 08:51 AM
BDiggity's Avatar
Its been awhile but i seem to remember my 525sc's, trs, 26p bravo @ about 4900rpm, 71 or 72 mph using gps phone app.
BDiggity is offline
