removing/shorting flare on prop. >
Old 06-23-2019 | 12:20 PM
Default removing/shorting flare on prop.
Educate myself the +/-'s of making this mod on props, especially 4bld which I have on my Checkmate 270?
thanks
PA.WOODCHUCK is offline
Old 06-23-2019 | 01:49 PM
Harder to get on plane without the diffuser ring. May add 50 rpms and 1/2 mph top speed.
Griff is offline
Old 06-23-2019 | 08:28 PM
Thanks for the reply, what's the correct part number for the bravo-1 24p? Can't find it on the mercury site.
Old 06-24-2019 | 09:21 PM
Tinkerer's Avatar
If you have a transom lift problem and want to settle the stern cutting the bell off will make a noticeable change and will settle the transom.
It will make it harder to get on plane but if you are not running exhaust through the prop you can pull the drive apart and seal the exhaust opening at the top of the lower using lexan and 4200 to seal.
This solves the getting on plane issue.
I did this on my cat.
Tinkerer is offline
Old 06-24-2019 | 09:38 PM
14 apache's Avatar
I cut them off boat gained nothing was a waist of time was on a 68mph boat gained nothing props slipped all the way to the top end.
14 apache is offline
Old 06-24-2019 | 09:39 PM
14 apache's Avatar
how fast was that cat??
Old 06-24-2019 | 10:06 PM
SB
As I mentioned on another thread the other day, Tinkerer and I , years back, found a fix independently of each other for all the damn slip from the bell cut off. On Bravo's and Alpha's.
SB is online now
Old 06-24-2019 | 10:08 PM
SB
Here, from Post #17 onward........
Prop help 2002 35 lightning w 730 hp
Edit in: LOl, did not see Tinkerer answered above too. I'm reading too fast trying to catch up. LOL.
SB is online now
Old 06-25-2019 | 09:46 PM
Tinkerer's Avatar
MY Daytona 26 does 112 @ this time. ( 800+ HP )
I think I am going to add turbos to it.
I don't like the looks of the M4 Procharger the engine was built to handle.
It either gets turbo's or I up the compression to 14 to 1 and run E85.
Engine should make 1000 HP that way.
The turbo's would be good for 1500 HP.
Tinkerer is offline
Old 06-25-2019 | 09:51 PM
Tinkerer's Avatar
14 apache
at 68 MPH you are not even beginning to make the drive act like a ski.
I don't think cutting the bell off a prop on a fully submerged drive is going to do much of anything at that speed.
The closer the drive gets to the surface the more it acts like a ski and WANTS to fully surface.
Cats don't like transom lift.
Pad bottom boats may benefit from a LITTLE transom lift. .
Tinkerer is offline
