I bought AFR heads and the head accessory holes are too small, has anyone drilled the >
Old 06-23-2019 | 12:43 PM
Default I bought AFR heads and the head accessory holes are too small, has anyone drilled the
I bought AFR heads and the head accessory holes are too small, has anyone drilled them to 1/2" threads. THe Mercruiser accesories are all for 1/2" studs to hang on.
cyrus77 is offline
Old 06-23-2019 | 02:07 PM
F-2 Speedy's Avatar
1/2 inch or 7/16's........I had the same issue on some 540's, I think one end of the AFR head is 3/8 and the other end is 7/16 ? been a while tho
F-2 Speedy is offline
Old 06-23-2019 | 03:07 PM
I had to drill them to 7/16 fine on Darts a couple of times, not a big deal
JaayTeee is offline
Old 06-23-2019 | 03:55 PM
14 apache's Avatar
Just use 3/8 bolts a little loose is just fine.
14 apache is offline
Old 06-24-2019 | 09:39 AM
i jused bolts and a small dab of blue loc tight
LTZCrew is offline
Old 06-25-2019 | 09:15 AM
I used 3/8" bolts with sleeves so no slop. Went to the local hobby shop and bought some brass tubing.
ThisIsLivin is offline
Old 06-25-2019 | 01:04 PM
Just drill out and tap. Very easy .
jwurl is offline
Old 06-25-2019 | 05:54 PM
Sleeve bearings. Cheap, easy.
https://www.mcmaster.com/catalog/125/1232
MILD THUNDER is offline
