Fountain Trim cylinder >
Old 06-30-2019 | 07:06 PM
splashandburn's Avatar
Default Fountain Trim cylinder
Looking for help finding a trim tab cylinder assembly for a 2004 Fountain 38 EC. This is the cylinder that's mounted on the trim tab itself. The tab will drop down if the boat sits and its leaking fluid out. Any help identifying this tab and cylinder would be greatly appreciated.
splashandburn is offline
Old 06-30-2019 | 07:23 PM
Likely a 280 k plane. Any hydraulic shop should be able to rebuild them
Crude Intentions is offline
Old 06-30-2019 | 07:48 PM
Thanks. Something we're looking for quickly. I see two part numbers listed (845739A10 and 844222A1). The second part number seems to be discontinued - any idea how we determine which one we need? ​​​​
Old 06-30-2019 | 08:20 PM
I believe the pin diameter is different. The old set had the K on the tab the newer set has the M.
Old 07-01-2019 | 07:49 AM
Pull it apart, see what style seals you have, measure them...and go on McMaster and order new seals. Easy to rebuild if you are remotely mechanically inclined (asssuming the cylinder and rod surfaces arent damaged). Did the same thing with my steering cylinders this spring.
https://www.mcmaster.com/hydraulic-seals
SS496 is offline
Old 07-02-2019 | 01:51 PM
Thanks I will pass that along
