2006 25 Baja outlaw trim tab switch relay >
Old 07-02-2019 | 12:15 PM
Default 2006 25 Baja outlaw trim tab switch relay
My starboard side trim tab will go down, but not back up. Motors will run, and I switched relays and wiring around to make it work. So it’s a bad relay. My question is does anyone have the wiring diagram for the outlaws. There is three to the starboard and three to the port. I know the middle wire is white on both. Just want to get it wired back correctly. Also where can I buy the relays?? Going to just replace both.
Mikeb6871 is offline
