sbc aftermarket cylinder heads
Hey all... thinking about upgrades to my 350 sbc and was looking at different cylinder heads. The engine was built from a Quicksilver reman SBC long block assembly, Quicksilver (merc) part # 87971R5. This is the GM 5.7 Litre "Non-Gen.+" 350 V/8, so these should be the older non-vortec heads. I was thinking of using a set of GM iron bowtie small port vortec heads (185cc intake runners) as I had very good results with them years ago on a sbc build when they first came on the market. Back then I paid just about $800 for a pair of bolt on heads, but I just priced them and was very surprised as they are now $828 per single head. So I came across the EngineQuest Hybrid Vortec Cylinder Head #CH350H heads or the CH350HA (assembled), anybody running these heads?
I would look from AFR to some of the offshore aluminum options.
AFRs are about $1700 a pair complete for 195s.
I ran some RHS version of the Vortecs...cast iron. I found they were high quality and performed.
They don't make them anymore...only aluminum versions.
The RHS's where taken on by EQ (Engine Quest). Small block and big block lines of cast iron heads.
