Bravo 1 props >
Bravo 1 props
Bravo 1 props
Old 07-14-2019 | 10:22 PM
Default Bravo 1 props
I'm currently running a 30P bravo 1. seeing 82(GPS)@5200 WOT.
I also have a 28P bravo 1. I have reached 82(GPS)@5400 WOT and still had a little more.
I really don't want to spin the motor hard. I cruise mostly from place to place. Short burst of WOT occasionally.
Is it better to use the 30P for all around cruise and maybe loose a little top end due to weight (fuel,people,coolers, etc)
or to use the 28P for all around use to cover all situations.
r,
Eric
es99eliminator is offline
Old 07-15-2019 | 12:36 AM
Using the 28 will put less stress on the engine and drive.
Griff is offline
Old 07-16-2019 | 09:13 AM
if you wanna sell the 30 ill take it off your hands
LTZCrew is offline
Old 07-24-2019 | 11:36 AM
bbladesprops's Avatar
Offshoreonly Advertiser
r,
Eric
Labbing The 30 may be a good option for you as it will allow the prop to spin up another 200-300 rpm and gain acceleration and a couple/few mph at WOT. You might lose a mph at cruise over the stock 30 but will gain the other benefits at top speed and still have better cruise than the 28.
Brett
[email protected]
bbladesprops is offline
