Gaffrig GPS Wiring help >
Old 07-15-2019 | 08:58 PM
fandango's Avatar
From: Solomons Island, MD, Vero Beach and Punta Gorda, FL
Default Gaffrig GPS Wiring help
Does anyone know where the single white wire attaches too. This is an older Gaffrig Precision Instruments GPS Speedometer with Recall. Wiring diagram would greatly help.
Thanks in advance.
Ed
fandango is offline
Old 07-15-2019 | 09:06 PM
Could it be the GPS receiver antenna?
zz28zz is offline
Old 07-15-2019 | 09:39 PM
Scarab28's Avatar
Possibly light
Scarab28 is offline
Old 07-16-2019 | 09:53 AM
fandango's Avatar
Thanks for replies. Hoping someone has hooked these up before. I know if start guessing on wires.....the wrong wire will fry unit.
fandango is offline
Old 07-16-2019 | 12:17 PM
Call Gaffric????
Padraig
Padraig is offline
Old 07-16-2019 | 01:03 PM
Dean Ferry's Avatar
Veteran: Air Force
check to see if this helps,:
https://www.riverdavesplace.com/foru...ut-100.149113/
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 07-16-2019 | 03:30 PM
You could disconnect single white wire, power up and see if GPS reception degrades.
zz28zz is offline
Old 07-16-2019 | 11:18 PM
Originally Posted by Padraig
Call Gaffric????
Padraig
Gaffrig Precision Instruments is now Livorsi
Griff is offline
Old 07-17-2019 | 09:39 AM
fandango's Avatar
Thanks to all. I have pretty much determined that the single white wire is the signal wire. Can either be landed on the antenna circuit or the NMEA 2000 GPS circuit for signal
Ed
fandango is offline
