30 or 32p prop? Can I turn the bigger wheel? >
Old 07-17-2019 | 08:10 AM
Default 30 or 32p prop? Can I turn the bigger wheel?
288 sunsation. (non stepped hull)
600sci
Bravo XR/ITS with short lower/sportmaster.
Prop shaft is about 2-3" below bottom of boat.
28 Pitch Bravo on limiter at 5500 RPM very easily.
78-80 MPH in a slight chop.
Satisfied with all other handling aspects at this point, tight turns, acceleration, time to plane, minimum speed, cruise and handling are fine/acceptable to me, not looking to get into expensive labbing or extensive testing, etc. Just want to prop the boat a few RPM lower so I can stay off the limiter and hopefully gain a few MPH.
Originally thought I could potentially turn a 32, a few guys mentioned single V's have a hard time in this size range going much over a 30P with out big power. I don't have any plans of changing current set up or adding power at this point.
Has me questioning my "estimated" ability to turn a higher pitch prop.
So, just curious what people think, before I plunk down a few hundred bucks on a prop that I can't turn, or that I still run into the limiter on, what do you think? 30 or 32? Planning to stick with the bravo 4 blade.
goinboatin is offline
Old 07-17-2019 | 08:29 AM
30’s will bring your rpm down to about 5200. When you go up in pitch you’re going to lose a little acceleration and plane a little harder
jbraun2828 is offline
Old 07-17-2019 | 09:01 AM
BBYSTWY's Avatar
Where are you located?
BBYSTWY is offline
Old 07-17-2019 | 09:12 AM
30, not 30's.
Well aware of changes in acceleration/holeshot. Not concerned, if I was willing to abuse it the boat jumps up on plane almost as quickly (relatively speaking) as previous lighter/smaller outboard boats i've had. No worries on that front.
Merc says 4800-5200 RPM range for the 600 sci, I'd be plenty happy if I could hit 5,000 with a 32 with a full tank of fuel. The 28 will bang the limiter at 5500 with 4 in the boat and 110 gallon tank topped off. So not sure a 30 brings me down as far as I would like?
Flintish area, Michigan. Why you close enough to let me try something?
Old 07-17-2019 | 09:14 AM
BBYSTWY's Avatar
I'm in southwest Michigan so kinda lol...I have a labbed 30 you could try if you want to drag the boat down here you're more than welcome....came off a cig I believe and it's cupped for a little more bow lift if I remember right but should at least get you in the ballpark to know if you can spin a bigger wheel or not...if you're interested pm me and I'll get you my number and we can set something up
BBYSTWY is offline
Old 07-17-2019 | 09:29 AM
If we make any plans to head that direction I'll certainly do so. Thanks for the offer!
Old 07-17-2019 | 09:30 AM
BBYSTWY's Avatar
Anytime
BBYSTWY is offline
Old 07-17-2019 | 12:22 PM
Until you try a larger pitch you won’t know where you are. Banging the rev limiter tells you you need larger pitch but doesn’t give enough specifics. Every inch of pitch will drop you about 200 rpm. So going up 2 inches will drop 400 rpm.
Crude Intentions is offline
Old 07-17-2019 | 12:25 PM
If you’re hitting the limiter that hard with that much weight on the boat a 32 would probably work. Or if you’re a little below you could have it labbed. Rule of thumb is 200rpm per inch of pitch.
IGetWet is offline
Old 07-17-2019 | 02:39 PM
Agreed, that's half the problem, is I don't know how much more RPM I'd have in the 28 to figure out if a 30 or 32 will be better. Not much luck finding something local, likely going to have to get into one of those bblades prop testing programs. Which is a pain, since i live 45 minutes from the lake.
