Looking for input 24 single outboard setup >
Old 07-18-2019 | 09:59 PM
Default Looking for input 24 single outboard setup
I’m thinking about converting my 1980 Carrera SS7M to single outboard. I asked this question over at Scream and fly but only got one response . I need more info . I’m sure most of you guys are familier with the Carrera. It’s the same / similar bottom to a 24 straight bottom Superboat . I figured you guys would have the most experience with a single outboard on this hull . From what I’ve read the Carrera is probably 1000lbs+ heavier than a superboat due to the raised deck and heavy layup . After a little research the 24 superboat guys run about 12-17” setback and propshaft 2-3” below bottom? I’m thinking about a 2002ish 3.0 liter 250 efi Mercury as the Hp can be upgraded without going too deep into the engine .Should I be looking for a 20” motor ? 25”? I’m trying to keep cost low , any recommendations for an engine jackplate / bracket ? I’m guessing with 250 hp I might get about 50 mph , good enough for a couple seasons . I just don’t know where to start as far as an engine bracket and shaft length . I’m thinking being an I/O boat with no motorwell I need a certain about of setback just for the engine to fit and turn . Thanks for any info .
tooslow is offline
Old 07-19-2019 | 06:30 PM
SUPERSTITIOUS's Avatar
Maybe consider a stainless marine bracket or similar with or without a swim platform give you a little set back ultimately you can decide whatever you want regarding 20 or 25 inch and place the bracket accordingly not sure how much dead rise do you have on that boat but I think a 20 inch should work fine. Another option is to add a jack plate gives you a little flexibility for performance/beaching the boat etc
Need lots of pictures!!
SUPERSTITIOUS is offline
Old 07-20-2019 | 01:01 AM
It has a 24 degree deadrise . Same lower hull as a 24 pantera or non step 24 superboat . I figured superboat owners had the most experience with a single outboard on the 24x7 hull . It may not be apples to apples as far as the setup because of the weigh difference . I just wanted a starting point .
tooslow is offline
Old 07-20-2019 | 05:34 PM
Are you going to keep it a single or go twin eventually?
If single I’d go 24” back, if going to twins, I’d do 20”.
A 20” motor will put the powerhead in water coming off plane, and the bracket will move w/where you mount the motor.
As in, a 25” motor will put the bracket 5” higher than a 20.
W/a platform you’ll want it above water line of course.
Im on my 3rd twin O/B vee and always use a bracket w/platform and integral floatation box.
The box on my twin bracket equals 340 lbs buoyancy/flotation.
Yrs ago there was a 24’ Carerra I/O converted to twin O/B.
Ran good. I almost bought it.
Twin O/B Sonic is offline
Old 07-21-2019 | 08:21 AM
Great point about the engine getting swamped when coming off plane . I’ll think I’ll go with a 25” for sure . It will probably be easier to find a 25” 3.0 Mercury anyway . I would be happy to get a solid 50mph , I just hope it’s not a total dog with 1 outboard. The engine I get will most likely not have a low water pickup , maybe start with propshaft 3-4” below the bottom?
tooslow is offline
Old 07-06-2020 | 06:05 AM
tripps's Avatar
Default 24
I'm doing same thing putting a 25 inch 250 mer c on a i/o boat have a 30 inch bracket if anybody has pics I would like to c them of bracket on transom!!!! Thanks
tripps is offline
Old 07-06-2020 | 07:31 PM
Google search 24' Jaws center console. They built many 24x7's with bracket / single outboard. They'll run about 55mph w/ 250efi. Good luck!!!
PARASAIL941 is offline
Old 07-07-2020 | 06:04 PM
Im doing a 25’ Checkmate IO to twin OB project but must have let my subscription lapse as this sites not letting me load pixs??
I have a very detailed thread on the project going on here though.
Search, “I got the itch again” if interested.
Old 08-16-2020 | 01:51 PM
tripps's Avatar
Default Superboat
Did my 24 put a 30 inch bracket on it worked great gearcase is 2 inches below water breaks just under cavacation plate needs to go up a bit goes 56 at 5600 a 22 or 24 chopper planes off great it's a 25 inch motor does not get drenched wen slowing down
tripps is offline
Old 08-16-2020 | 03:37 PM
tripps's Avatar
tripps is offline
