Go Back  Offshoreonly.com > Technical > Electronics
Where does the trim wire connect to >
Old 08-07-2019 | 05:19 PM
Default Where does the trim wire connect to
I am not sure how these trim wires connect to if anyone could help.
zerolash is offline
Old 08-07-2019 | 08:40 PM
242LS is offline
Old 08-08-2019 | 07:01 AM
Are you sure those are for the trim switch? With the eye rings and colors I am thinking they may be for the MerCathode system. Just guessing.
Good Luck
GLENAMY 242SS is offline
Old 08-08-2019 | 08:00 AM
F-2 Speedy's Avatar
Agree ^^^^
F-2 Speedy is offline
Old 08-09-2019 | 10:25 AM
Default I have a brown and orange wire
I don’t know if the trim limit was ever hooked up. Do I connect orange to blue on solenoid and brown to green?
zerolash is offline
Old 08-09-2019 | 11:37 AM
I agree with the guys above about the mercathode. Mercathode unit in the boat was probably removed but the part mounted on the bottom of the transom assy is probably still there and that’s where these wires are coming from.
IGetWet is offline
Old 08-09-2019 | 11:45 AM
Ok I guess I can look for that if not just leave I’m hooked I guess. Thanks for the help!!
zerolash is offline
Old 08-10-2019 | 07:19 AM
Should I buy one of the mercathode?
zerolash is offline
Old 08-10-2019 | 08:29 AM
Mercathode wiring and if your not suffering from excessive electrolsys and your zincs are doing there job and your replacing them as needed you wont need a Mercathode system
Bt Doctur is offline
Old 08-10-2019 | 08:34 AM
F-2 Speedy's Avatar
I think I have a couple used ones,
