Coil question >
Coil question
Coil question
Old 08-12-2019 | 11:44 AM
Default Coil question
Guys,
New to the forum. I know these forums are a wealth of information, so I thought I'd try here first! Just bought a 98 Baja Hammer with a 7.4L (non mag)/bravo one setup. I recently had a coil failure and when I google the number on the coil (392-8055 70 1) the majority of what comes up is the number 392-8055 70A2??? Is this the same coil? For my own information, is the coil I have on my engine have an internal resistor, or external?
Thanks!!!
Tombaja is offline
Old 08-12-2019 | 12:04 PM
F-2 Speedy's Avatar
What ignition do you have ?
F-2 Speedy is offline
Old 08-12-2019 | 12:18 PM
That would probably be helpful to know!
I will try to get over to the storage building in the next day or so to check.
So Mercury used more than one type in that year?
Tombaja is offline
Old 08-12-2019 | 12:26 PM
F-2 Speedy's Avatar
The part # is for a thunderbolt IV or V............ I've heard they have an internal resistor in them.
https://inboarengin.com/392-805570-1
Old 08-12-2019 | 12:34 PM
If I am reading things correctly, the difference between the IV & V is the V's ability to advance/retard the ignition timing based on a knock sensor?
Tombaja is offline
Old 08-12-2019 | 12:51 PM
I was thinking about getting something with a bit hotter spark like the Pertronix 40511, but was unsure of the resistance required.
Tombaja is offline
Old 08-12-2019 | 01:06 PM
SB
The TBIV and V ignitions (most carb engines) use a coil that , if I remember correctly, has .6ohm resistance. If you use a coil with different resistance you run a chance at frying the Thunderbolt timing module/amplifier. The OE coil does not use a resistor to step down the voltage. Just the old points type did.
98% of the computer controlled Merc engines used the ACDelco EST coil. Only a few used the Thunderbolt style. These will fire a SC engine with 7pounds boost and 5k+ rpms. It. also, is plenty fine for most marine engines that use this style coil.
The Thunderbolt V differentiates itself from the IV by using a knock sensor and a timing strategy (Mean Best Timing) in the module, vs a fixed 'curve' in the IV's module. Yes, a few V's did not use a knock sensor.
SB is online now
Old 08-12-2019 | 01:16 PM
Interesting...
Pertronix does sell a .6 ohm coil.
I was initially concerned about the engines poor starting (it just kind of started by catching on a couple of cylinders then everything would start firing) but after my wife caught glimpse of the giant spark arching across the high output and the primary negative, I knew what part of the problem was. Of course not before I had to do the float of shame from the dock to the trailer because it decided it had had enough.
Tombaja is offline
Old 08-12-2019 | 02:10 PM
F-2 Speedy's Avatar
Put the OE coil on it, their cheap and dont put anything on it that says MSD ( may start deteriorating )
Old 08-12-2019 | 09:07 PM
BUP
you have to use a coil that matches the primary and secondary resistance of the OEM coil no matter if it is T bolt IV or V or the est set up. The big block Merc s Black side 454 / 502 used a est ignition set up not the same T bolt set ups.. There is couple of sources to buy the exact coil or even better but its very few sources -- Sierra is NOT one of those sources. . Way to many poor quality copies from secondary China makers.
The EST coil is a NON oil filled coil. Pertronix does not have the coil your looking for unless they added it to their line up but I doubt it.
Many Merc efi engines used the T bolt set up as well. The small blocks including many 6.2 and the 4.3
BUP is offline
