Large assortment of high end parts and motors
Huge list of parts. More will be added.
5- steel billet flywheels 250 each
1- aluminum Billet flywheel 325
5- 3 stage pumps 350 each
5- bell housing coolers
Available plate sizes 6-8-13 150-350 each
6 sets JE used pistons 400 each
1 JE set New Blower 4.530 550
2- KSE hi pressure belt driven pumps new 675 each
Assorted roller cams blower and NA 225 each
100s of SS AN + plumbing parts TBD
4- Holley / SX pumps 175 each
Harden push rods Misc sizes 100 set/16
2- used Billet oil pans 500 each
2- 14 qts pans + pumps steel 450 each
4- round large oil coolers 125
4- merc dry dump pans 841853 , 1800 each
3- wide rail Billet oil pans 600 each
2- sets , insky red zone EZ lifters new 950 each
Weldon pump - 2025A like new 650
Dana 1000 tabs / pumps 1200
Assorted offshore engine mounts V/Cat steel and SS built 300-800 a set
Fuel Injectors , multiple sets / sizes 50 lbs and up 275 set of 8
Dan Olson stringer mount cooler 300
Set of dart 360 heads 1800
Set of brodex BB4 CNC heads 7500
Set of jewel shaft mount rockers 1100
100s of new jesel shaft rockers 55 each
Gaffrig controls , single set dual trim switch 250
1/2 fuel heads 65 each
2-Pair of stellings blacks or tans 2500 each
2- Stellings tails 1000 set
4- Whipple 2.3 blowers less snouts 2200 each
CMI headers - 2000
1- Dart 555 motor, best of all parts. Big Chief heads single Dom , 1000 hp build. 19k
4- sterling 510 aluminum dart block motors. 18k each
2- Donovan 11.2 deck aluminum block motors 19k
Headed out to Cali to pick up this parts list and more.
This is just and idea of parts and prices.
I will be getting more details and accurate pricing, parts, and condition of all parts.
All parts are top of the line.
There is more not listed and I will update when I get there. Any interested let m me know.
1st come , 1st serve. Deposits can be taken. I will not hold anything with out money.
If you are hesitant to buy or questionable on parts, condition or details, do not put a deposit down.
I’m going off what I know so far.
PRICES MAY GO UP ON MOTORS DEPENDING ON RIGGING / ACC WITH THEM. Also other larger parts may be the same situation.
