Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Another stringer repair question >
Old 08-23-2019 | 08:11 AM
BDiggity's Avatar
Default Another stringer repair question
Getting ready to do the repair for the two side stringers. About the last 12-18" have rotted out (been told this is common on Cafe's due to where they mount the trim tabs).
My dilemma is how best to repair:
1) cut tops off back to where rot stops plus some, dig out old wood, replace with new, resin/glass top
2) cut out the the rotted section plus some, & lay all new stringer
3) cut out the entire stringer length & replace with full length.
#3 sounds possibly overkill but i am not sure if #1 or 2 isn't recommended because its not a single solid piece of wood running from bulkhead to transom.
Thoughts?
BDiggity is offline
Old 08-23-2019 | 09:56 AM
Thoughts?
I am possibly going to be in the same situation. I am curious as to what answer you get. I have a 33 checkmate and not positive yet but I think I have a couple feet of rot under the engine area, hoping it doesnt continue further. I dont even know how you would replace the whole thing. cracking the boat in half at the joint seems like so much work.
770guy is offline
Old 08-23-2019 | 11:05 AM
I’m no expert but believe the method is to cut off the tops, dig out the rotten stuff, insert new material with resin, cap off the top. Enjoy!
Baja Rooster is offline
Old 08-23-2019 | 12:03 PM
BBYSTWY's Avatar
From my experience....I have done stringers on a few boats and have always been told the method rooster posted with a few extra points....
I've been told to not do a straight vertical edge in a stringer and to cut each one into a wedge and glass them together so there's not a vertical weak point....like this...=====//===== if that makes sense lol
You also want to rough up the inside of the existing glass after removing the wood and I have always encased the new wood with a layer of glass around it and resined everything very well before putting the new wood in so it all bonds to the existing boat then matte and resin to cap it sand smooth gel or paint and enjoy
Right or wrong that's how I've done it and never had one rot out again so I guess it's ok?? hahaha
If glassdave sees this I'm sure he can offer input on products to embed the wood with and resin and whatnot...good luck!!
BBYSTWY is offline
Old 08-23-2019 | 01:17 PM
BDiggity's Avatar
Great info, thanks guys!
Yes we planned to cut at the angle in order to give more surface area & prep the inside of stringer shell.
BDiggity is offline
