Mercury racing 525efi power steering pump >
Old 08-28-2019 | 05:45 AM
fastlane40's Avatar
Default Mercury racing 525efi power steering pump
Can anybody tell me anything about the pressure valve mounted on the pump?
fastlane40 is offline
Old 08-28-2019 | 08:37 AM
Assuming your talking about the "check valve" screwed to back of pump (that the ps hose attaches to)...it is a one-way valve that (in twin eng applications) prevents overflowing non-running eng's reservior...primarily when, only, one eng is running.
Hope that helps!?!...Jason
@InshoreOff
JBmarine is offline
Old 08-28-2019 | 04:44 PM
fastlane40's Avatar
Thanks for the reply Jason.
Is that valve able to be screwed out?
If it’s not there can it affect the operation of the pump?
I fitted 525’s into a older boat and have no power assist.
I believe everything is connected right.Still have cable from helm and it is fine.
Seems like the pump is not pumping??
Old 08-28-2019 | 04:51 PM
F-2 Speedy's Avatar
Did you bleed the air out of the system, are you running a cooler
F-2 Speedy is offline
Old 08-28-2019 | 04:55 PM
fastlane40's Avatar
Yes ran it for a long time.
Should be self bleeding by wheel turns?
Has a cooler.
Old 08-28-2019 | 05:42 PM
F-2 Speedy's Avatar
If there is any foaming in the fluid it still has air in the system, I remove the serpentine belt and spin the pump with a drill while turning the wheel lock to lock.......you sure the lines arent switched
Old 08-28-2019 | 08:00 PM
The easiest way to verify pump operation is by testing output pressure with gauge set.
If you have one or more external add-on cylinders, you may want to disconnect hoses and make sure seals are not holding the rams tight from freely moving.
Since your setup is cable with power assist...I would disconnect cable from drive, and remove from the actuator. Make sure tube (that cable slides thru) is cleaned, greased, and cable slides thru freely. While cable is out make sure at helm wheel turns with ease.
If cable moves free, the actuator tube is internally clean-greased, and the pressure is good from pump...then issue is the actuator itself.
Jason
@InshoreOff
JBmarine is offline
Old 08-28-2019 | 09:46 PM
fastlane40's Avatar
There seems to be no turbulence in the pump reservoir.
i have checked the cable and it is free.
Need to check output pressure next.
Saginaw rack,high pressure line is on left looking at transom?
Old 08-31-2019 | 11:34 PM
fastlane40's Avatar
Put a gauge on the pump outlet and nothing.
No resistance at all when turned by hand.
Can only be the pump??
Old 09-02-2019 | 05:48 AM
fastlane40's Avatar
Pulled the pump from one of the race motors and straight away power steering.
It is very jerky and ratchety.How long should it take to get all the air out of the system.
Ran it at idle turning wheel back and forth for 3 minutes.
F2 Speedy thanks for your help.
