Best Drives for Fountain 35 Lightning >
Old 08-31-2019 | 07:17 AM
Default Best Drives for Fountain 35 Lightning
Hello all, seeking advice for cost effective drives upgrade for a 99' 35 lightning single step with fresh twin 625 hp Atteco engines. Currently Bravo 1 drives 32p props. Currently only 84.5 mph Boat needs another 200 rpms, gets to 5100 rpms, thinking Bravo 1 30p props or swapping out lower units with speedmasters or imco shorties? Then down the road replace the uppers? Or should I just find a pair of SSM IIIs or similar? Trying to get a real top speed.. thank you!
Bears3460 is offline
Old 08-31-2019 | 08:29 AM
Did you buy the boat from Shipyard Marine? I was eyeing that boat, looks like a great buy! I’m sure the Fountain family will chime in with the best route to take on lowers/props. Congrats on your purchase!
SecondWind is offline
Old 08-31-2019 | 09:31 AM
I’d ask Bill at ateco how tight you can spin those motors up. You may be able to prop it for more than 53/5400.
endeavor1 is offline
Old 08-31-2019 | 10:16 AM
seafordguy's Avatar
I would start by seeking the help of one of our prop vendors. Much cheaper than re-rigging the entire boat.....
seafordguy is offline
Old 08-31-2019 | 10:30 AM
Yes sir we are putting that call in. Dyno sheets top out at 5400 654hp
Old 08-31-2019 | 11:08 AM
F-2 Speedy's Avatar
Changing from a bravo to #3's would probably be a minimum of 8-10k to derig and do the transom work and this doesn't include any parts
F-2 Speedy is offline
Old 08-31-2019 | 11:15 AM
Sounds like should keep bravo and replace lower unit with a shorty?
Old 08-31-2019 | 11:41 AM
Few things, was the dyno in marine dress? You know marine headers, alternator, water pump sea pump etc.
as an example my buddy has the same boat, X is 19 3/4, hills 30 five blade prop and it runs 84 in 96 high humidity.
That is stock 525’s that were right around 535HP on the dyno.
His best speed was with 29 P5 hydros in cool weather 87 mph. You need to see what your X is with that HP you should be able to hit 90 easy
Wildman_grafix is offline
Old 08-31-2019 | 12:31 PM
seafordguy's Avatar
I don't know anything about fountains, but is 32 a lot of prop for 650hp?
Old 08-31-2019 | 12:39 PM
A 32 bravo is more like a 30-31 in most props. Not sure why Bravo does that but it isnt that much of a prop if the motors are really 625HP in marine dress.
