Moisture displacement and carb fogging... >
Old 09-01-2019 | 10:52 AM
Default Moisture displacement and carb fogging...
Does this product (see photos) look safe/useful for protecting motor/drive parts by displacing moisture and does it seem safe for fogging my carburetors during 4-6 week periods of non-use?
Thanks,
Tom
F14A water jet is offline
Old 09-01-2019 | 10:56 AM
14 apache's Avatar
I would use 2 stroke oil for fogging motor.
14 apache is offline
Old 09-01-2019 | 12:07 PM
Thanks,
Tom
Penatrating oil usually has some type of acid in it to penetrate rust. I definitely wouldn't use it. Like stated just fogging oil or run a soup mix thru the engine and fuel system.
underpsi68 is offline
Old 09-01-2019 | 12:49 PM
For only 4-6 weeks of non-use, I wouldn't worry abt it.
Merc (and a few other companies) make dedicated fogging oil. I would definitely use that instead of penetrating oil.
zz28zz is offline
Old 09-01-2019 | 02:25 PM
Most penetrating fluids, as previously described are not a Fogging oil and would more than likely remove any trace of lubrication from the cylinder walls - which is what you are trying to achieve in Fogging...
Merc has a dedicated fogging oil that works well (as does 2 stroke oil mixed in) - but fogging oils generally have a creeping agent that causes the oil to spread - right up the spark plug electrodes too so you would be looking at that as well...
FYI - A lot of boats are launched a sit in marinas for several weeks waiting for the owners to arrive - generally speaking of Mercruiser stock power/ tow boats .... crank and go recreation boats)
The spray you have could be used to spray down the engines if you were worried about external corrosion (watch out for live electrical - shut off battery switch)
speicher lane is offline
Old 09-01-2019 | 04:56 PM
4-6 weeks isn’t long enough to worry about fogging, but it is long enough for e-10 to go to sh!t. Marina gas (non ethanol) will save you a lot of heartache. Alcohol is for the cup holder not the gas tank. ��
ph1971 is offline
Old 09-01-2019 | 08:55 PM
Merc has a dedicated fogging oil - creeping agent - right up the spark plug electrodes
Taking all three points above into consider...GREAT answers and support/thoughts.
Old 09-01-2019 | 08:57 PM
I try to use non-ethanol and I am religious about Stabil (for ethanol when using e-10) in every tank (just in case).
